What voice equipment do i need?
Aug 2nd, 2007
For Implementation of an IP telephony solution in a building. I want to support Voicemail, Videoconferencing ? and I need PSTN connectivity for 60 concurrent calls.
All users will require extension mobility.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Thu, 08/02/2007 - 03:08
  • Hall of Fame,
    Founding Member
Why don't you look to a 2851 router with CCME.
Latest version 4.2 support extension mobility.
No other equipment is needed, only your choice of telephones. I recommend you use exclusively ISDN to connect to PSTN.
tinu.karki Thu, 08/02/2007 - 06:55
Does the 2851 need an additional module to make it work, also what would i use if i needed to install more than 240 phones? this is the maximum amount of phones that the CCME supports.
sarmentrout.qwest77 Thu, 08/02/2007 - 12:53
Depending on budget and if you have more than 240 users you could do a couple of things that come to mind immediately:
1. Unified Communications Manager Business Edition with the 2851 router that contains multiple VWIC-1MFT and/or VWIC-2MFT modules and a complimenting suite of DSP (PVDM) modules to handle both the data requirements and isdn voice requirements. This solution supports both the voice and voicemail requirements. You can add VT advantage to this system to allow peer to peer video conferencing but short of that, I think you need another system to handle that piece.
2. Multiple CCME routers dividing the users to keep the user limit under requirements. If you want voicemail, you will need to look into Unity Express and purchase that module as well. You will need to define how many concurrent VM connections you want to allow. As above, you can add VT advantage to this system to allow peer to peer video conferencing but short of that, I think you need another system to handle that piece.
Hope this helps...
dford333 Sun, 08/05/2007 - 14:17
you need a Callmanager 4, publisher and subscriber MCS-7815
CME doesnt support extention mobility.
You also need to intergrated Unity in this cluster.
you may also need telepresense for conferencing
Cisco Catalyst 3550/60 to support 60 connections and power over ethernet.
A Cisco gateway router to support IPWAN/PSTN
paolo bevilacqua Sun, 08/05/2007 - 14:50
  • Hall of Fame,
    Founding Member
dford is right as for the mentioned installation size CCM is a better choice than CME.
Couple of precisations:
- 7815 is kind of oldish. On a budget, look for the 7816 that is entry-point for rack-mount.
- CME does support extension mobility in lates version 4.2
dford333 Sun, 08/05/2007 - 15:10
as for preferences I wouldnt use EM with CME, but as for your budjet thats another choice.
and that is correct EM is supported on CME
Prerequisites
?Cisco Unified CME 4.2 or a later version.
Restrictions
?Extension mobility on remote Cisco Unified CME routers is not supported; a phone user can log into any local Cisco Unified IP phone only.
but not for remote users. also you want video conferencing, and If you are well versed in CME than yes you should otherwise, for time and convience, use a callmanager 4 7815 - 7825.
you will not have any restrictions preforming what you need to do. you just need to know how to do it.
