08-02-2007 04:52 AM
Hi ,
I have a site to site VPN and VPN clients
and for VPN traffic i got no nat and sysopt cpnnection permit-ipsec.
I want to configure port based access-list for the vpn client for ssh access to one of my vpn clients to a machine onside my LAn network.
if I remove the sysopt connection permit-ipsec will my existing VPN branch tunnel go down.
and can I use named access-list for the vpn client so i can get the ssh access ?
I m using PIX 515 E with IOS 6.3
08-02-2007 05:02 AM
zaheer, you can remove sysopt conn permit-ipsec and write the access list into the outside interface.
no sysopt conn permit-ipsec
access-list outside_access_in permit tcp host
access-group outside_access_in in interface outside
As far as it taking the vpn down temporarily, I tested this on an ASA and the vpn remained up after I removed the sysopt command.
08-02-2007 05:11 AM
Thank you for replying Adam
Will check that.
08-02-2007 05:12 AM
No problem, hope it helps.
Why all the 2 ratings?
08-02-2007 05:17 AM
Hi Adam,
Just one more question before i try it.
I have got VPN group for my VPN clients with split-tunneling.
and each vpn group has an access-list.
Also i have an access-list for my outside to inside traffic.
So will i have to merge all me VPN group ACLs to the outside to inside ALCs ?
08-02-2007 05:19 AM
What do your split tunnel acl's look like?
08-02-2007 06:03 AM
the vpngroup and the ACL for that is as follows
access-list acl_test permit tcp host 10.0.0.55 host 192.168.x.x eq ssh
vpngroup test address-pool abc
vpngroup test split-tunnel acl_test
vpngroup test idle-time 1800
vpngroup test password ********
10.0.0.55 is my VPN client
and my server is in 192.168.x.x range
08-02-2007 06:11 AM
access-list acl_test permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.255.0
access-list outside_access_in permit tcp host 10.0.0.55 host 192.168.x.x eq 22
08-02-2007 06:21 AM
so its gooing to be like my acl_test is my intresting traffic for VPN and acl outside_access_in is for the ssh
thank you Adam.
