Multicast scalability
deanyoung
I am running a network comprising of Catalyst 6513's with SUP7203B's. at present we have 800 VLAN's as we make use of a VLAN per access layer switch model.
I know have a problem that as soon as I enable multicast routing my SUP720's CPU runs at 100% and the system goes into a slowdown.
I would like to knwo where I can find information on the scalability of Multicast?
Dean
15 Replies 15
Edison Ortiz
Did you enable CEF ? IP Multicast Routing is done in hardware on the 6500s.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/mcastv4.htm
Yes CEF is enabled. I get the following error in the log:
%MCAST-SP-4-MET_THRESHOLD_EXCEEDED: Multicast Expansion table has exceeded 98% of its capacity and is reaching its maximum
%MMLS-SP-6-MET_LIMIT_EXCEEDED: Failed to allocate MET entry, exceeded system limit of (65536) entries. Number of times MET limit is exceeded in the last 1 min : 430
Did you enable PIM in all Vlans ? What mode did you select ? sparse or dense ?
Yes, I am using sparse mode.
cjnwodo
I assume that all access layer switches are layer 3 and are also running multicast -PIM. I also assume that all or a large number of the 800 VLANs are interested in the multicast traffic that you are sending. If both assumptions are true, then you will run into this issue because the core 6513 is replicating the traffic out a majority of those VLAN interfaces.
Basically a lot of interfaces in the OIL [out going interface list]. The best place to find information on multicast scalability on the 6500 would be to look at the prodcuts sheet of the Catalyst 6500 and the supervisor engine as well as the line casrds that you are using.
Try here:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheets_list.html
No all my access layer switches are Cisco 2950 / 2960 / 2970 L2 switches
Having checked your error message in Cisco's Error message decoder:
1. %MMLS-6-MET_LIMIT_EXCEEDED: Failed to allocate MET entry, exceeded system limit of ([dec]) entries. Number of times MET limit is exceeded in the last 1 min : [dec]
This message indicates that the maximum MET entry limit has been exceeded. MET entries cannot be allocated by MMLS.
Recommended Action: The total number of OIFs is too large to fit in the MET table. Subsequent shortcuts or OIFs will be switched by the software. There is no workaround.
Related documents- No specific documents apply to this error message.
2. %MMLS-6-MET_LIMIT_EXCEEDED: Failed to allocate MET entry, exceeded system limit of ([dec]) entries. Number of times MET limit is exceeded in the last 1 min : [dec]
I suspect that there are routers hanging off the L2 switches that are running PIM and are interested in the multicast traffic. Can you confirm?
That is correct. Thye are running sparse mode.
Did you configure a RP ?
Why do you need to enable PIM in all interfaces ?
Yes I did. I presume it is best practise to do so?
sh ip pim rp
Group: 239.255.255.253, RP: 137.158.152.241, v2, next RP-reachable in 00:00:35
Group: 239.255.255.250, RP: 137.158.152.241, v2, next RP-reachable in 00:00:35
Group: 234.21.81.1, RP: 137.158.152.241, v2, next RP-reachable in 00:00:34
Group: 224.0.1.35, RP: 137.158.152.241, v2, next RP-reachable in 00:00:59
Group: 224.0.1.40, RP: 137.158.152.241, v2, next RP-reachable in 00:00:34
Group: 224.0.1.60, RP: 137.158.152.241, v2, next RP-reachable in 00:00:34
Group: 239.255.219.45, RP: 137.158.152.241, v2, next RP-reachable in 00:00:39
Group: 239.0.0.6, RP: 137.158.152.241, v2, next RP-reachable in 00:00:54
Group: 224.0.1.22, RP: 137.158.152.241, v2, next RP-reachable in 00:00:34
We are using the Sup720-3B with around 200 Vlan configured for multicast. We have a MET table usage of 2%, so I expect for you a usage of less than 20%. I would enable multicast vlan by vlan and check when the MET increase unexpected. Than you could check with ip mroutes summary, where the OIF's are used. With show platform hardeware capacity you cloud check the MET.
router-720#show platform hardware capacity multicast
L3 Multicast Resources
IPv4 replication mode: ingress
IPv6 replication mode: ingress
Bi-directional PIM Designated Forwarder Table usage: 4 total, 0 (0%) used
Replication capability: Module IPv4 IPv6
1 ingress ingress
2 ingress ingress
3 ingress ingress
4 ingress ingress
5 ingress ingress
6 ingress ingress
7 egress egress
13 egress -
MET table Entries: Module Total Used %Used
7 65526 1060 2%
We removed multicast from a number of VLANS and below is the output after the change.
Router-720#show platform hardware capacity multicast
IPv4 replication mode: egress
Module IPv4 IPv6
7 egress egress
8 egress egress
9 egress egress
MET table Entries:
7 65526 1038 2%
8 65526 0 0%
#sh ip multicast
Multicast Routing: enabled
Multicast Multipath: disabled
Multicast Route limit: No limit
Multicast Triggered RPF check: enabled
Multicast Fallback group mode: Dense
Multicast DVMRP Interoperability: disabled
A word of caution: One of the 'gotcha's' of multicast is that once you enable it natively, you have to enable it on every router in the network. If you don't do this you run the risk of breaking it. For e.g.
1) In the case of a failure when the RPF to a particular multicast source is routed via a different path [the one with no multicast enabled] on the even of a failure of a link or router
2) remember that on a LAN that conatins only routers [no receiving hosts- so no need for IGMP] if there is multicast feed on the LAN, all routers on that VLAN will receive a copy of the multicast feed because by default [without PIM snooping enabled on the switch] the switch will flood the multicast feed out all ports in that VLAN. This means that every router on the VLAN has to process switch this packet before they drop it [if they don't need it] this takes up CPU, whereas if multicast was enabled on all routers, the routers that don't need the feed will drop the packet less CPU utilization because their OIL for that group would ne null.
I guess what I'm trying to say is make sure that if you diable multicast on a VLAN, that VLAN will NEVER be used as the RPF to any multicast source in the event of any failure.
So I guess there are no error messages left. Now you have to enable multicast step by step on the vlan's, until the error messages apperars again. I guess there is a nasty client or something else connected to a vlan, which cause a lot of multicast entries.
