Upgrading from 2.3 SDM to 2.4 and new options
Aug 2nd, 2007
I have a 2821 router with IOS 12.4(6)T2.
Into the adition task menu, there is a new option called C3PL.
This option is off for my IOS, which will be the correct IOS to enable this option?
If I want to block p2p traffic, but the users change the port...
Best regards
If a version of Cisco SDM later than version 1.0 is already installed on the router, use the Cisco SDM automatic update feature to install the latest files on the router. Cisco SDM automatically checks Cisco.com for more recent versions of Cisco SDM, downloads them to your PC, removes the old Cisco SDM files from memory, runs the squeeze flash: command if necessary, and copies the latest files to the router. The update feature is available from the Tools menu. Choose Tools > Update SDM > From Cisco.com.
