vpn client and router routing issues
Aug 2nd, 2007
so my vpn client connects to the router and gets an ip , 192.168.6.X
on the network I have 192.168.1.x, 5.x and 10.x but I can only access the 6.x stuff from the vpn client.
when I do a route print on windows I can see that the, 5.0 and 10.0 routes are not there, I only have the 6.0 so that's why.
now I'm wondering if there is a way to configure my router so that when the vpn client connects it will populate in windows the, 5.0 and 10.0 as well?
srue Thu, 08/02/2007 - 06:38
Do you have split tunnelling enabled?
Can you post the (sanitized) config for the vpn settings, including related ACL's and nat statements.
pamirian76 Thu, 08/02/2007 - 10:31
so what I want to do, is that when I connect to the router using vpn client and getting the ip address of 192.168.6.X, I want to be able to go everywhere I want inside the network 192.168.X.X
I want access to, 5.0 and 10.0
any suggestions, pointers, anything?
thank you.
