VPN ip range
Aug 2nd, 2007
Hi guys,
Just wondering if it is possible to set up a site to site with both sites on the same inside address range. For example. 192.168.16.0.
so can I write an access list eg access-list 100 permit ip 192.168.16.0 255... 192.168.16.0 255..
Cheers.
srue Thu, 08/02/2007 - 07:16
  • Blue, 1500 points or more
one side or the other needs to nat their network BEFORE the crypto map is applied..
so the nat acl will match the newly nat'ed address space
The side that doesn't do any nat, will have to make sure their crypto acl's match the newly nat'ed address on the other side also.
