Network Assistant 5.0
Aug 2nd, 2007
I have three cisco access points on my network, all have the same SSID. Is there a way to get all three to show up in NA versus just the one? Right I see 1 AP with three connections.
aghaznavi Wed, 08/08/2007 - 17:55
  • Silver, 250 points or more
I think Cisco Network Assistant supports only autonomous access points. Access points that are managed by a wireless LAN controller are not supported. Cisco Aironet 350, 1100, and 1200 series. Network Assistant supports them only if they run a Cisco IOS image. For more information please click following URL:
http://www.cisco.com/en/US/products/ps5931/prod_release_note09186a00807aea81.html#wp658039
aborole Wed, 08/08/2007 - 18:05
  • Cisco Employee,
Are the 3 access points added as members of a community and have separate IP addresses or are they neighbors of a member device ? Do you have other access points with separate SSIDs and they show up as separate entities ? if that is the case then your problem could be similar to another known issue where neighbors having same hostnames show up as single entity with multiple links from member device.
