2811 router unable to see controller T1
Aug 2nd, 2007
I have a 2811 router running C2800NM-ADVIPSERVICESK9-M), Version 12.3(11)T. When I add a WIC T1 CSU/DSU I can't see the controller T1. This is a 2811 router. Any help appreciated. Thanks
jason-calbert_2 Thu, 08/02/2007 - 08:43
Jerry,
I have tried this but I'm unable to enter the command IOS does not reckonize it. Any suggestions.
Jason
jerry.mcrae Thu, 08/02/2007 - 09:03
ive had this happen before - you need the wic-1dsu-t1-v2 and not the wic-1dsu-t1.
ruesch-eng Thu, 08/02/2007 - 09:03
I had this same exact problem several months ago when I upgraded my 2811 to c2800nm-advipservicesk9-mz.123-11.T11.bin. All commands related to the card type, controllers, and serial interfaces disappeared from my config. So I rolled back to the original code and had to reconfigure the router. In April, I upgraded to c2800nm-advipservicesk9-mz.124-10b.bin, and it worked fine.
