CSS 11000 Problem with load balancing
Aug 2nd, 2007
I have inherited a used Cisco Css 11000 from a friend. I am trying to set up a test environment to get a jump on my classes this upcoming semester. So far I have had no problems setting it up to load balance connections between four "servers".
But i started to notice something rather strange with it the other day. One server is getting alot more connections then the other three when i test. Here are the stats
Service State Conn Weight Avg load
test1 Alive 22 1 2
test2 Alive 52 1 2
test3 Alive 15 1 2
test4 Alive 142 1 39
So when i take test4 out of that content group the other three servers load balance fine. It is just when that one is in there does it do this.
Does anyone have any ideas on what it might be? Because I am totally lost.
Gilles Dufour Fri, 08/03/2007 - 00:54
what kind of loadbalancing method do you use ?
Can we see the content rule ?
Gilles.
ogieogilthorpe Fri, 08/03/2007 - 05:14
here is the conf
CSS11050# sh run
!Generated on 07/31/2007 10:10:48
!Active version: ap0500605
configure
!*************************** GLOBAL ***************************
restrict ftp
username test des-password xxxxxxxx superuser
arp timeout 60
arp wait 15
no restrict web-mgmt
no restrict xml
snmp name "test-load1"
snmp contact "555-1212"
snmp location "here"
snmp community test01 read-only
app
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 3
!************************* INTERFACE *************************
interface e1
description "UPLINK"
interface e2
description "TO-SWITCH"
interface e8
description "FAILOVER"
!************************** CIRCUIT **************************
circuit VLAN1
description "MAIN_VLAN"
ip address xxx.xxx.xxx.xxx 255.255.255.0
ip virtual-router 1 preempt
ip redundant-interface 1 xxx.xxx.xxx.xxx
!************************** SERVICE **************************
service test1
active
service test2
active
service test3
active
service test4
active
!*************************** OWNER ***************************
owner test
content test1
vip address xxx.xxx.xxx.xxx
protocol tcp
port 80
sticky-inact-timeout 30
add service test1
add service test2
add service test3
add service test4
advanced-balance sticky-srcip
active
CSS11050#
