Lost OSPF adjacentcy
Aug 2nd, 2007
We have a PIX 6.3 that has been working with no problems, suddenly we lost the OSPF adjacentcy to our edge router.
I can see the Neighbor in the edge router and the database has the routes, but they are not populating the route tables of the edge router and the PIX is not getting the default route from the edge router.
Debugs show I am getting the hello from the pix, but they a re not updating each other's route tables.
The PIX also sees the edge router.
I can see the PIX knows the edge route is a neighbor, but does not get the default route from the PIX.
The inside network should be getting the degfault route from the PIX, instead, it is getting it from our MPLS router, which it should do under faulover conditions.
The routes are not getting to the edge router at all from the PIX and they were before.
All physical connections are good.
Are there any suggestions where to look?
Overall Rating: 5 (1 ratings)
Edison Ortiz Thu, 08/02/2007 - 10:15
Make sure you aren't facing any MTU mismatch between the neighbors and they are both in the same area with compatible network types.
Are you using the default network type (Broadcast) ? If so, who is the DR ?
Can you post configs ?
You can also try turning debug on ip ospf hello and verify the PIX is not blocking multicast packets.
wilson_1234_2 Thu, 08/02/2007 - 12:52
Thanks for the reply.
This was working until this morning, what could have changed?
I have the router set to ignore ospf MTU on the interface that should be forming the adjacency.
I can see the hello from the PIX getting to the router.
There is another PIX in the same lan connection that is showing the edge router as DOWN/DROTHER
