Easy VPN problem
Hi gang. Total noob with no routing experience except for what SDM tells me to do(yes, master). Setup Easy VPN and Nat following the wizards. Can connect to the VPN server like the wind blows (using Cisco client v4.8) but I'll be damned if I can't ping another device on the network. Can ping the internal and external interfaces only. I really just want to terminal service in after connection. Any help/clue would be greatly appreciated. Please see attached diagram / config. Thanks
spremkumar Fri, 08/03/2007 - 03:12
  • Red, 2250 points or more
Once you are connected with vpn client are you able to ping 172.16.58.65 ?
If yes which ip address you are trying to ping and which is not working at present ?
regds
