Different subnets
Aug 2nd, 2007
if i have three site having common vpls services and i would like to use the three different subnets in each site then how they will communicate with each other.... as VPLS create the virtual ethernet switch type of connection for the all three sites..... so the different subnet sites will communicate with each other.....
swaroop.potdar Fri, 08/03/2007 - 03:47
VPLS provides you with a single broadcast domain.
Since you want 3 different subnets, may be you can use the MPLS VPN service. Or you can ask the service provider to provision 3 P2P atom links between the 3 sites in a triangular fashion.
