Starting CCNP studies, now I need LAB equipment!
I really want to have a home lab as nothing really beats the tactileness of the hardware. I have some hardware from work, but I'd like to know what's the best (new preferably) hardware to get for the CCNP.
Right now I have the Cisco Press BSCI and BCMSN books (cert guide and study guides) and I want to get hardware to match up with those books.
Can 2600 level routers handle this stuff?
Do I need a frame relay generator?
Do I need powered Ethernet?
Do I need wireless access points?
Would three routers and three switches be enough?
mohammedmahmoud Thu, 08/02/2007 - 12:18
Yes the 2600 level router would be nice, for frame-relay you can use a 2500 router or even a 2600 router acting as a frame-relay switch, and moreover i think 3 routers and 3 switches would be fine, as for the powered Ethernet and the wireless access point they are not a must.
Mohammed Mahmoud.
steve_steele Wed, 08/08/2007 - 22:54
I have 3 2620's but could not run BGP on them. I also have 3 2610XM's which would run BGP.
I could not get any of them to run MPLS though.
I do have one 3725 that would run MPLS ( The basics of which are discussed in ONT ) but as it's the only router I have there wasn't a great deal I could do with it.
A 2511 access server is very handy for console access to all devices. I also used it for injecting rip routes for redistribution in some of the more complicated scenarios I mocked up.
I'm about to start BCMSN which I've put off whilst I found a couple of suitable switches. I'm going to try and manage with 1 3550 and 1 2950 but I suspect that I might have to get another 1 of each to lab things up properly Subject to the sale of a kidney.
I have a 8 port network module (NM-8AS I think) in one of the routers which can be configured as a frame relay switch.
If your unsure what technology will run on what router the Cisco Feature Navigator is really useful
I hope some of that will be of use.
prasenjitmedhi Wed, 08/08/2007 - 23:12
I've bought stuff from a CCIE certified guy on ebay,
He sells a CCNP lab as well. Now I dont mean to advertise this one guy but it worked out fine for me, I bought some 3620's from him.
Heres the link:
His lab setup includes:
6 - Cisco 3620 Routers, 64/16 RAM, 12.3 Enterprise IOS
12 - WIC-1T Serial Modules
6 - Cisco NM-1E2W Modules
1 - Cisco 2509 - 2 Serial, 1 Ethernet, 8x Asynchronous Ports (Terminal Server)
1 - Cisco 2521 Router, 4 Serial Ports, 1 ISDN Port
2 - Cisco 2950-24 Switches (Latest IOS)
1 - FREE Internetwork Expert CCIE Lab Training Manual:
CCIE Routing & Switching Lab Workbook Volume I (IEWB-RS-VOL1) Printed Version
10- FREE Ethernet Cables
6- FREE DCE/DTE Crossover Cables
10- AC Power Cords
1- Console cable kit
8- Console Rollover Cables for 2509
HTH! Please vote if it was helpful.
cyphur353 Thu, 08/09/2007 - 05:53
I vote for dynamips/dynagen for the BSCI, ONT and ISCW exams. Pick up a couple 3550 or 3560 switches for BCMSN or rent some rack time.
