error opening tftp
Answered Question
Aug 2nd, 2007
i cannot connect to the tftp server.
i'm connected via console to the router 1841. my pc is the tftp server.i want to make a copy of the flash to the tftp server but i ve an error ( see the attachment).
please help !!
Correct Answer by mohammedmahmoud about 9 years 7 months ago
To do tftp, you must have IP connectivity with the router, may be through the fastethernet port of the router (connect your PC to the router via a cross-over cable - or via a straight cable through a switch - and give them IPs in the same subnet) and then you can do your tftp.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (3 ratings)
mohammedmahmoud Thu, 08/02/2007 - 12:59
  • Green, 3000 points or more
Please change your tftp server, try using tftpd32, and first of all please make sure that you can ping the IP address of the tftp server.
HTH,
Mohammed Mahmoud.
dom.a Thu, 08/02/2007 - 13:04
what i use is a tftpd32 v2.74
regards
mohammedmahmoud Thu, 08/02/2007 - 13:06
Can you ping the IP address of the tftp server ?
HTH,
Mohammed Mahmoud.
dom.a Thu, 08/02/2007 - 13:08
i'm connected via console port. so the tftp server is my pc i use to connect the router via console port. how can i ping the router ? help !
Correct Answer
mohammedmahmoud Thu, 08/02/2007 - 13:12
HTH,
Mohammed Mahmoud.
Richard Burts Thu, 08/02/2007 - 13:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dominique
While I believe that tftpd32 is a good tftp server and that there might be reasons to switch to it, I do not see any evidence of that in the output that you posted. What that post shows is that the router is attempting to access the server and is timing out. That suggests that the router is not getting any response from the server. There are several things that might produce these symptoms.
- Can you verify that there is IP connectivity from the router to the address you are giving as the server address? (ping is a good way to demonstrate this)?
- Is there any possibility that there is a firewall between the router and your PC that is not permitting the tftp packets?
- Is it possible that your PC is running a firewall that is not allowing the tftp packets?
- Is it possible that the TFTP software on your PC is not running or that it is experiencing some error? (if your TFTP software has any logging capability does it show that it is receiving any request, does it show that it is responding)?
If you can clarify these items we may get closer to solving your problem.
Rick
dom.a Thu, 08/02/2007 - 13:18
excuse to all !!! i have no IP connectivity and i try to connect to the tftp server !! what a bad way !!!
i thought that i put already an IP to my interface...
regards !!!
mohammedmahmoud Thu, 08/02/2007 - 13:25
hi Dominique,
No problems at all, we all have our glitches, thanks for using the rating system.
BR,
Mohammed Mahmoud.
