Deny TCP reverse path check
Hi I get following message from PIX ver 7.0:
PIX-1-106021: Deny TCP reverse path check from 192.168.0.150 to 192.168.0.250 on interface dmz
106021: Someone is attempting to spoof an IP address on an inbound connection. Unicast Reverse Path Forwarding (Unicast RPF), also known as reverse route lookup, detected a packet that does not have a source address represented by a route and assumes that it is part of an attack on your firewall.
but extraly, we have virtual ip with netscaler in the dmz, then do http://virtual ip address, from 192.168.0.150, phisical server ip is 192.168.0.250. How to fix or disable Unicast Reverse Path Forwarding? if disable, what is happend?
ben
Overall Rating: 5 (2 ratings)
srue Thu, 08/02/2007 - 14:40
  • Blue, 1500 points or more
look for the following command in your config:
ip verify reverse-path interface ....
Although, it'd be best to figure out what was causing the log message. Basically the message means the dmz interface received a packet with the source address matching a known inside network address.
srue Thu, 08/02/2007 - 19:55
its intended as a security feature to prevent address spoofing.
should be no impact if you disable it.
sonybabu2k1 Tue, 09/27/2011 - 00:10
hi,
Try adding a static route to the source IP towards the interface through which it comes. so that a route is present for that IP.
Sony
vipulagrawal Fri, 09/07/2012 - 00:57
Guys,
Need a serious help for this antispoofing issue :
Sep  6 14:19:42 vrd-swi-asa-01-pri %ASA-6-302013: Built inbound TCP  connection 25447904 for IP-PBX-WAN:10.98.2.12/49383 (10.98.2.12/49383)  to Mitel-Front:172.20.128.5/7011 (172.20.128.5/7011)
Sep  6 14:19:42 vrd-swi-asa-01-pri %ASA-6-302014: Teardown TCP  connection 25447903 for IP-PBX-WAN:10.98.2.12/49382 to  Mitel-Front:172.20.128.5/7011 duration 0:00:00 bytes 6845 TCP FINs
Sep  6 15:09:38 vrd-swi-asa-01-pri %ASA-1-106021: Deny TCP reverse path check from 10.98.2.12 to 172.40.0.1 on interface Corp-WAN
These are the logs of my WAN firewall..Problem here is traffic originating from 10.98.2.12 when hitting to 172.40.0.1 is getting denied, while hitting to any other destination is allowed.
I think "ip verify reverse path" check the source IP is coming from correct interface or not, here it is coming from IP-PBX-WAN for all other traffic but why not for 172.40.0.1 ?
Please suggest.
oszkari Sun, 09/09/2012 - 10:22
"Ip verify reverse path" checks two things:
1. is a route present for that specific source?
2. is the packet  comming on the right interface?
I would suggest to check the routing to exclude possible assymetic routing issues. If everything looks alright then it might be a real spoofing attack.
