L2TPV3 over IPSEC bridging
I'm trying to bridge a VLan using L2TPV3 over IPSEC.
Everything is working properly when the computers have an MTU manually lowered to 1300. But it doesn't work for computers with default MTU.
The show L2tp session all shows no packets being dropped because of MTU so it seems that it is the IPSEC encapsulation that is making the packets too big.
I've tried using IP TCP ADJUST-MSS as well as lowering the MTU on the router interfaces but it doesn't help.
Cisco bug CSCek46765 mention a problem with LT2PV3 over GRE which could be the one I'm hitting here but the workaround of using IP MTU 1538 doesn't work for me as loopback interfaces can't be set with an MTU that big.
Is anybody successfully running LT2PV3 over IPSEC. What did you do to fix the MTU issue?
steve_mils Mon, 12/08/2008 - 07:12
Removing that command will mean that you will see fragmentation - meaning traffic will get process-switched leading to high CPU load on your device. Did you ever experience this? If so did you solve the problem another way?
I ask because we see the same problem. We need 'ip pmtu' to stop CPU problems but at the same time we can't have it because it breaks some servers! Catch-22.
Marcin Zgola Wed, 10/03/2007 - 14:40
can you email me a copy of your config?
I am trying to do same thing
pseudowire-class vlan-xconnect
encapsulation l2tpv3
ip local interface Loopback1
ip tos reflect
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr aes 256
group 5
crypto isakmp key xxx address
crypto ipsec transform-set ESP-AES256-SHA esp-aes 256 esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to
set peer
set transform-set ESP-AES256-SHA
match address 100
interface Null0
no ip unreachables
interface Loopback1
description L2TPv3 Tunnel Source
ip address
ip mtu 1420
ip tcp adjust-mss 1300
interface FastEthernet0
description $ETH-LAN$$FW_OUTSIDE$
ip address 24.x.x.215
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
interface Vlan1
no ip address
ip mtu 1400
xconnect 1 pw-class vlan-xconnect
ip route 0.0.x.x.155.121.209
access-list 102 permit ahp host host
access-list 102 permit esp host host
access-list 102 permit udp host host eq isakmp
access-list 102 permit udp host host eq non500-isakmp
access-list 102 remark IPSec Rule
access-list 102 permit ip host host
access-list 102 deny ip any any log
Marcin Zgola Thu, 10/04/2007 - 08:52
Ok, I am not sure if i am asking to much, but how this VLAN tunneling excatly works? Can you email me configuration on both ends?
Here is what I am trying to do:
SW1 (3VLANS) --- Router --- IPSEC/VPN --- ROUTER --- (3VLANS) --- SW2
When you look at this. I want Sw1, and sw2 to share same VLANid and broadcast domain.
Is this possible?
