Cisco Call Manager CDR Analysis and Reporting
Aug 2nd, 2007
Hi, I have a CCM 4.2 cluster and I installed the plug in CDR Analysis and Reporting following a traditional instuction provided by the plug in installer.
When I open it, that is: (Application>Cisco Call Manager Serviceability>Tools>CDR Analysis and Reporting) I get the message: "The page cannot be displayed
The page you are looking for is currently unavailable"
Can anyone tell me what is happenning?
Majdi Harb Fri, 08/03/2007 - 02:56
  • Silver, 250 points or more
hi
CAR comprises a group of complementary services, which you can activate in the Service Activation window in Cisco Unified CallManager Serviceability. Before you can launch CAR from the Tools menu in Cisco Unified CallManager Serviceability, you must activate the CAR services:
Choose Tools > Service Activation.
Check the check boxes next to the following CDR services:
? Cisco CAR Scheduler
? Cisco CAR Web Service
? Cisco SOAP-CDROnDemand (optional). If you are using a third-party billing application that accesses CDR data via an HTTPS/SOAP interface, activate this service.
Note: Activate the CAR services on only the first node, where the Cisco Unified CallManager database resides.
u can also access CAR directly:
https://:8443/car/Logon.jsp
hth
/majdi
nicocerti Sun, 08/05/2007 - 13:46
Majid
Thank you for your response
I?ve been looking for the services you talk about in the CallManager Serviceability page, but those services are not there, the only service it has related with CDR, is the Cisco CDR Insert and it is activated. I looked for the CAR services you recommend me to activate in the services of the server (Administrative tools>services) and I found "Cisco CRA engine" service, it is stopped and I tryed to start it, but it doesn?t work because an unspecified error. Could this be the cause of my problem?
Thank you
Nicolay
Rob Huffman Sun, 08/05/2007 - 15:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nicolay,
The CRA Engine is not related to your issue here (it is the engine for CRA/IPCC function) :( Have a look at the info in the attached document. Maybe try uninstalling and then reinstalling the CAR Plugin;
Cisco Unified CallManager Serviceability Administration Guide, Release 4.2(3)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008070ec27.html#wp1041050
Hope this helps!
Rob
