Ethernet packet in L2 switch
Aug 2nd, 2007
HostA is connecting in L2 switch. When host A sent out a packet,is the packet broadcast to all hosts of the vlan? If no host of the L2 switch reply, then is it will forwarded to the Gateway?
PatsFan12 Thu, 08/02/2007 - 16:36
Is this a VLAN (native) within a switch or a trunked VLAN going across multiple routers?
eric.huihk Thu, 08/02/2007 - 18:40
What differences between native vlan and trunked vlan?
Anyway, there is a connection for this L2 switch to the Gateway.
mhellman Fri, 08/03/2007 - 09:42
  • Blue, 1500 points or more
Generally speaking, and making a lot of assumptions about the details...no.
A unicast packet will go directly to either:
1) the MAC address of a host on the same VLAN
2) the MAC address of a router that can get to that host (including a default gateway)
However, if a switch receives a frame with a destination MAC not in its CAM table, it will send the frame out on all ports.
