route traffic to VPN
Answered Question
Aug 2nd, 2007
We would like to access the PC from R3 (192.168.16 and 192.168.17) to R1 (192.100.0 and 192.168.101) segment. There is one VPN between R1 and R2. we would like to make use of the VPN session to do it. However, we cannot ping 192.168.100.0 segment. anything missing? pls advise
Best regards
Follow is the config for your refer
R3
! 192.168.16.1
inter fastether 0
ip address 192.168.16.1 255.255.255.0
inter fastether 0
ip address 192.168.17.1 255.255.255.0
inter serial 0
ip address 172.16.254.17 255.255.255.252
ip route 192.168.100.0 0.0.1.255 172.16.254.18
R2
! 192.168.31.0
inter fastether 2
ip address 192.168.31.1 255.255.255.0
inter serial 0
ip address 172.16.254.18 255.255.255.252
crypto isakmp key owt address 203.x.x.x
crypto map mymap 104 ipsec-isakmp
description VPN from 192.168.31.0 segment to tw 192.168.100.0/23 segment
set peer 203.x.x.x
set transform-set myset
match address 104
access-list 104 permit ip 192.168.31.0 0.0.0.255 192.168.100.0.0 0.0.0.255
access-list 104 permit ip 192.168.31.0 0.0.0.255 192.168.100.1.0 0.0.0.255
ip route 192.168.16.0 0.0.1.255 172.16.254.17
R1
! 192.168.100.1
crypto isakmp key owt address 200.x.x.x
description VPN to to hk
set peer 200.x.x.x.
match address 104
access-list 104 permit ip 192.168.100.0 0.0.0.255 192.168.31.0 0.0.0.255
access-list 104 permit ip 192.168.101.0 0.0.0.255 192.168.31.0 0.0.0.255
interface GigabitEthernet0/1
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/2
ip address 192.168.101.1 255.255.255.0
Correct Answer by jdevoll about 9 years 8 months ago
The following ACL will specifically allow 16.5 and 17.5 to 100.200 and 101.200 and vice versa. You may or may not want to make it more inclusive, but this does exactly what you asked for, no more.
R1
access-list 104 permit ip host 192.168.100.0 host 192.168.16.5
access-list 104 permit ip host 192.168.101.0 host 192.168.17.5
R2
access-list 104 permit ip 192.168.31.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 104 permit ip 192.168.31.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 104 permit ip host 192.168.16.5 host 192.168.100.200
access-list 104 permit ip host 192.168.17.5 host 192.168.101.200
Overall Rating: 5 (2 ratings)
jdevoll Thu, 08/02/2007 - 18:28
It looks like access-list 104 isn't including the right traffic but there isn't enough information given to be sure.
What is the IP address of the PC?
Am I correct in saying that you want to access the PC from both 192.168.16.1 and 192.168.17.1?
leungcm Thu, 08/02/2007 - 18:39
Yes, from 192.168.16.5 (or 192.168.17.5) to PC 192.168.100.200 and 192.168.101.200.
Best regards
sundar.palaniappan Thu, 08/02/2007 - 19:22
  • Green, 3000 points or more
The traffic from R1 to R3 and vice versa is missing from the crypto access list. Add this config and try.
R2:
access-list 104 permit ip 192.168.16.0 0.0.0.255 192.168.100.0.0 0.0.0.255
access-list 104 permit ip 192.168.17.0 0.0.0.255 192.168.101.0.0 0.0.0.255
R1:
access-list 104 permit ip 192.168.100.0 0.0.0.255 192.168.16.0 0.0.0.255
access-list 104 permit ip 192.168.101.0 0.0.0.255 192.168.17.0 0.0.0.255
Sundar
Correct Answer
jdevoll Thu, 08/02/2007 - 19:49
R1
R2
Pavel Bykov Thu, 08/02/2007 - 23:32
  • Silver, 250 points or more
When setting up ACL for crypto maps, you have to specify traffic in BOTH directions. Use advise from above posts, and it should work.
