Eigrp Routing Update missing neighbors
Edison Ortiz Mon, 08/06/2007 - 05:54
After the routes go missing, can you ping the neighbors ?
Are the neighbors known via a serial or ethernet interface ?
What type of router and IOS are your running ?
Can you describe your network topology ?
Can you post configs ?
Pavel Bykov Mon, 08/06/2007 - 06:00
If there are no routes in the table that means either connected router does not have networks to advertise or no session is established. We need more information before troubleshooting your problem.
try issuing on both sides:
"show ip eigrp neighbors"
"show interfaces"
"ping ADDRESS_OF_NEIGHBOR"
"show running"
