Avaya & PIMG MWI Integration
jones_amy
On the PIMG do the MWI on and off fields need to match what avaya has? Can any one tell me where avaya keeps that information?
eschulz
If you're using digital PIMG (e.g. emulating 7434ND sets) then the lwc-store and lwc-cancel feature buttons will be used for MWI control. DTMF feature access codes are not needed.
If you are using analog PIMG (with Avaya's Mode Code in-band VMI integration) then MWI On/Off feature access codes are needed. I don't have Avaya docs in front of me but if you do need this information still I could try to dig it up for you.
-Eric
If I am using 8434 phone type for the avaya phone type how do program the phone so unity funcions properly?
