Design
Aug 2nd, 2007
I have one main site with CM 4.1 and unity. I have a remote site that?s is connected of a WAN. The Main number for the remote site comes in across the E1 circuit at the main site then goes across the WAN link. How can I ensure the remote site can still receive calls on their main number if the WAN link goes down? Is there a way I can monitor the WAN link and if it goes down route the main number back out the PSTN to a single POTS line at the remote site?
Chris Deren Fri, 08/03/2007 - 07:38
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
If the WAN link is down you should failover to SRST, you have some choices there:
use alias command to direct the call to local phone
use TCL AA script to answer the call and allow caller dial an extension
use translation rules and if you want send the call out to PSTN
HTH,
Chris
ajames2007 Fri, 08/03/2007 - 08:41
Thanks for that. I do have SRST enabled on the router for internal and external calls.
where would I use the Alias, TCL AA or transaltion rule woudl this be on the main site gateway where the main number comes in also how will it know if the link has gone down?
thanks
Chris Deren Fri, 08/03/2007 - 08:54
  • Hall of Fame,
I misread your initial post, I though you said the main number comes into the remote site.
What does the main number call flow do?
Chris
ajames2007 Sat, 08/04/2007 - 00:08
ok at the Main site I have a 2800 with 30 E1 Channels. 50 DDI number are pushed down this E1. for various phones at the main site and a main number for the remote site
I then have an IP link (LES 10) to our remote site where 10 phones are connected back to the CM. at this remote site I have an SRST GW with a single pots link pluuged in so they can make internal and outbound calls. if the LES 10 link goes down when some one calls the main number for the remote site they would not be able to get through so I wanted to be able to check if that LES 10 link goes down and if it does route the call back out the PSTN to the single pots link plugged into the SRST GW at the remote site.
Thanks for your help and advice
