Reverse Telnet to a console
Answered Question
Aug 3rd, 2007
I have a 2621 router and a 2651XM router. Currently, the 2651XM router is defective. Is there a way to telnet to the console of the 2651XM using reverse telnet on the 2621 on port 2065 (AUX). I connected a rollover cable from AUX of 2621 to the console port of 2651XM. Please tell me if this is possible.
John
Correct Answer by mohammedmahmoud about 9 years 11 months ago
Yes it is, under the line aux of the 2621 add the following commands:
transport input telnet
stopbits 1
no exec
then do "telnet x.x.x.x 2065", where x.x.x.x is an active IP on the 2621.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
Correct Answer
mohammedmahmoud Fri, 08/03/2007 - 03:36
  • Green, 3000 points or more
stopbits 1
no exec
HTH,
Mohammed Mahmoud.
John Patrick Lopez Fri, 08/17/2007 - 04:44
Thank you very much Mohammed. I can now reverse telnet to the console. I don't know what I did wrong before. My configuration was just the same but now it is working. At least you verified that this is possible and your config helped me a lot. Thanks.
mohammedmahmoud Fri, 08/17/2007 - 04:59
John,
You are very welcomed :), i am glade i helped, and thank you for using the rating system.
BR,
Mohammed Mahmoud.
