mohammedmahmoud Fri, 08/03/2007 - 04:23
  • Green, 3000 points or more
MPLS stands for Multi Protocol Label Switching, its a way of switching packets based on labels (fast way of packet switching on backbones, plus the extra available features that it introduces), review this document and it'll supply you with the elementary facts:
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_q_and_a_item09186a00800949e5.shtml
And for more details:
http://www.cisco.com/en/US/tech/tk436/tk428/tsd_technology_support_protocol_home.html
[edit] There is also a fine book that you can really depend on:
Cisco Press MPLS Fundamentals by Luc De Ghein, CCIE No. 1897
HTH,
Mohammed Mahmoud.
Pavel Bykov Fri, 08/03/2007 - 04:29
  • Silver, 250 points or more
read the documents Mohammed provided, but please beware of it's complexity before deploying it in production environment. Meaning you should really know the purpose of why you want it and be able to understand what is going on.
guruprasadr Fri, 08/03/2007 - 05:24
  • Gold, 750 points or more
HI Kumar, [PLS rate if HELPS]
MPLS is a packet-forwarding technology which uses labels to make data forwarding decisions. With MPLS, the Layer 3 header analysis is done just once (when the packet enters the MPLS domain).
In addition to above all the Post, pls refer link below:
PLS RATE if HELPS
Best Regards,
Guru Prasad R
