IPsec VPN - limit access
Aug 3rd, 2007
We need deploy IPSEC between two sites A and B (A is PIX 7.0 B is router 800 12.4)
But we need limit access in following way:
from A to B : few PCs remote desktop to one PC
from B to A : one PC to one server on one port...
I know that ACL defining interesting traffic should be mirrored but traffic what we need is not symetric... Is possible restrict access only for traffic i specified???
srue Fri, 08/03/2007 - 04:57
mirror your acl's as you normally would. Then define regular interface acl's at either end to control/allow only the traffic you want in/out.
On the pix, if you have 'sysopt connection permit-vpn' enabled though, all vpn traffic will bypass interface ACL checking, so be careful if that command is enabled.
