https service doesn't works through CSS
Aug 3rd, 2007
I have 2 CSS 11501, and they work fine.
The only problem that has is that it doesn't work one of the content HTTPS.
This is the configuration that I have:
service server54
ip address 172.16.10.46
keepalive port 443
keepalive type tcp
active
service server55
ip address 172.16.10.146
keepalive port 443
keepalive type tcp
owner https
content web
vip address 10.102.1.28
add service server54
port 443
protocol tcp
application ssl
advanced-balance ssl
add service server55
active
group web
add service server52
add service server53
active
I've left only one of the services active. In the CSS I see the requests but no package comes to the server.
The http service has the same addresses and does not have any problem.
What can happen?
RODRGUTI Fri, 08/03/2007 - 19:53
Did you check that the service is alive? (CSS# show service summary)
Did you check that the CSS is showing service hits for that content rule? (CSS# show summary) when you are doing requests?
If the users are the ones that are opening the connections, please change the group configuration:
group web
add destination service server52
add destination service server53
add destination service server54
add destination service server55
active
After trying all above, if you keep having the problem, the best way to know what is happening is get simultaneous captures, in the switch(s) where the CSS is directly connected, and you will see the CSS receiving the traffic, and forwarding the traffic to the backend servers.
You will confirm or at least you will see if the CSS is not the problem.
- Rodrigo.
