DMVPN interesting traffic
Aug 3rd, 2007
I have currently set up a DMVPN between the hub and two spokes.
What I wanted now is to force a specific traffic (SMTP for example) to go through the tunnel and divert everything else for the WAN connection that also exists.
Can anyone tell me how I can do this?
Here is the hub config of my VPN:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key THEKEY address 0.0.0.0 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
interface Tunnel0
bandwidth 1000
ip address 10.20.0.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication DMVPN_NW
ip nhrp map multicast dynamic
ip nhrp network-id 100000
ip nhrp holdtime 360
ip nhrp cache non-authoritative
ip tcp adjust-mss 1360
ip ospf network point-to-multipoint non-broadcast
ip ospf priority 20
delay 1000
tunnel source FastEthernet0/0.1
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile SDM_Profile1
Paulo
yusuff Sun, 08/05/2007 - 00:18
Hi Paulo,
Traffic being encrypted is BASED on the routing table, so anything that points to Tunnel0 is going to be encrypted.
In order to force specific traffic (e.g. SMTP), you may have to configure Policy-Based Routing (PBR) i.e. configure class-map to match specific traffic and set the next-hop to Tunnel0. For all other traffic set the next-hop to WAN interface. That way, you will only force selected traffic to Tunnel0.
Note: I haven't tried this scenario myself, but interesting Qs... pls try PBR and let us know if it works for you.
my 2 cents.
Yusuf
ccie16351 Sun, 08/12/2007 - 14:42
Hi Yusuf,
it is nice to catch you on the net. With all the respect to you personally and your knowledge, I guess the sequence in the PBR is the other way around of what you suggested, since the default is to send the encrypted traffic to the tunnel based on its subnet/routing table, then the 1st sequence in the PBR is to match against SMTP and set its interface to the physical interface and the next PBR sequence wouldn't have a match. This way all unmatched traffic earlier will go through the tunnel.
Pls comment.
Sami salim
