CEF ip accounting type function?
mohammedmahmoud Fri, 08/03/2007 - 05:17
  • Green, 3000 points or more
Kindly use NetFlow as follows:
"ip route-cache flow" under the main interface or "ip flow ingress" under the subinterface and then use "show ip cache flow" to display it.
HTH,
Mohammed Mahmoud.
Richard Burts Fri, 08/03/2007 - 08:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Edward
I agree with Mohammed that NetFlow is a very good tool and that it is what you should use. In recent versions of code it is possible to have NetFlow identify the top talkers (makes it much easier than having to interpret the output of show ip cache flow. This link will give you information about this capability:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00805e11ab.html
Rick
