VPN Client
Aug 3rd, 2007
I use a pcf to connect to a remote asa. It works from several locations, however there is one that it does not. I included a route print from my workstation while connected from both a working and non working location. The top route print is the non working. The difference i noticed between the two of them is the second line. On the non working the gateway is the address the ASA assigns to the client 10.10.101.106 on the bottom route print the gateway is correct 10.10.101.1. I believe this is where the problem is. If anyone has input on this it is much appreciated.
grahambartlett Tue, 08/07/2007 - 07:03
hI
Can you also show a ipconfig on both working and non-working.
Also let me know what address your clients are being given from the ASA.
