MQC Police Action
Aug 3rd, 2007
Dose anyone know if it is possible to use multiple actions in a policy-map when policing?
It is possible to configure but I?m not sure if it works
The configuration:
policy-map FR-POLICE
class class-default
police cir 128000
conform-action transmit
exceed-action set-prec-transmit 3 ! The first exceed action
exceed-action set-frde-transmit ! The second exceed action
interface Serial0/3/0
description To FR-Switch S0/0
ip address 150.50.12.1 255.255.255.0
encapsulation frame-relay
service-policy output FR-POLICE
In this case I want to set the prec and also set the DE bit
mohammedmahmoud Fri, 08/03/2007 - 06:04
hi,
Marking multiple fields in the same packet with CB Policing is called multi-action policing, i think that i've tried this once and it worked out.
HTH,
Mohammed Mahmoud.
royalblues Fri, 08/03/2007 - 11:59
I dont think it will work.
When you exceed the police limit, you tell the router to set the Prec value. once this is done there should not be any further lookup
moreover i think in IOS when you mention the exceed-action twice, the later one would replace the one entered before
Narayan
