Data mismatch in call_type_half_hour
Aug 3rd, 2007
Our environment include a CCM 4.1 cluster, a CRS IP-IVR server and an IPCC Enterprise 6.0 system. Counting the calls handled by Contact Center for a specific CallType (5006) I've found a data mismatch...
From call_type_half_hour table definition in DBSchema document:
"CallsHandledHalf in is the total number of calls of this call type handled
in the current half-hour.
Termination_Call_Detail records with a
CallDisposition of 6, 13, 14, 28, 29, 30, or 34 are
counted as CallHandled.
Note Valid for both IPCC and standard ACD
targets that use translation routes."
On t_termination_call_detail there are 33 calls, in t_call_type_half_hour there are 14...
In attached file can find the queries on DB and the results.
vkapoor5 Thu, 08/09/2007 - 06:34
Try this Bug - CSCma25888
1) Locate 'pbodb80.ini' ('pbodb70.ini' for 4.6.x) file in '
Home>\shared\PowerBuilder' directory.
2) Open the file in notepad
3) Locate following section
PBDateTimeFmt='\'yyyy-mm-dd hh:mm:ss.fff\''
4) Modify the date format appropriately. For French system it would be
PBDateTimeFmt='\'yyyy-dd-mm hh:mm:ss.fff\''
5) Restart 'Jaguar' and 'IIS ADmin' Services
