3548 keeps rebooting
Aug 3rd, 2007
I have a 3548 that keeps rebooting. Text of the reboot is below:
C3500XL Boot Loader (C3500-HBOOT-M) Version 12.0(5.2)XU, MAINTENANCE INTERIM SOFTWARE
Compiled Mon 17-Jul-00 18:42 by ayounes
starting...
Base ethernet MAC Address: 00:04:c1:a9:88:c0
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 18 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 3236864
flashfs[0]: Bytes available: 375808
flashfs[0]: flashfs fsck took 5 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:c3500xl-c3h2s-mz.120-5.WC5.bin"...###################################################################################
File "flash:c3500xl-c3h2s-mz.120-5.WC5.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C3500xl Software (C3500xl-C3H2S-M), Version 12.0(5)WC5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 28-May-02 11:41 by devgoyal
Image text-base: 0x00003000, data-base: 0x0034A3C8
Initializing C3500xl flash...
flashfs[1]: 18 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 3236864
flashfs[1]: Bytes available: 375808
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete.
...done Initializing C3500xl flash.
C3500xl POST: System Board Test: Passed
C3500xl POST: Daughter Card Test: Passed
C3500xl POST: CPU Buffer Test: Passed
C3500xl POST: CPU Notify RAM Test: Passed
C3500xl POST: CPU Interface Test: Passed
C3500xl POST: Testing Switch Core: Passed
C3500xl POST: Testing Buffer Table: Passed
C3500xl POST: Data Buffer Test: Passed
C3500xl POST: Configuring Switch Parameters: Passed
C3500xl POST: Ethernet Controller Test: Passed
C3500xl POST: MII Test: Passed
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes of memory.
Processor board ID FAA0503X1ED, with hardware revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:04:C1:A9:88:C0
Motherboard assembly number: 73-3903-07
Power supply part number: 34-0971-01
Motherboard serial number: FAA05010LLC
Power supply serial number: PAC0435084G
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: FAA0503X1ED
SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE!
I started the switch with no problem yesterday. Configured the switch and then reloaded. This is when the problem occurred. Has anybody run across this and is there any way to get the switch to boot back to a command line for configuration?
Jagdeep Gambhir Fri, 08/03/2007 - 12:26
Hi ,
We are getting this error ,
Known Defect
cat3500-xl is not able to boot up if there is a line "logging buffered 1000000 debugging"
in the configuration. The switch shows an error message of "INSUFFICIENT MEMORY TO BOOT
THE IMAGE!" and keep reloading itself.
Workaround:
Decreseing the logging buffer from 1000000 to 500000 in cat3k configuration file will resolve the booting problem
c3548XL-2(config)#logging buffered 500000 de
If still issue is there then get it RMA'd
Please rate helpful posts !
~JG
