'global address overlaps with mask'
Aug 3rd, 2007
static (inside,outside) <global ip> <local ip> netmask <local ip netmask>
When I enter the above in my pix 501 (mind that whats in the <> is an ip address) I get an error message that says 'global address overlaps with mask'
Any ideas?
Overall Rating: 4 (1 ratings)
Jesterino Thu, 08/09/2007 - 02:04
You're translating your whole inside network. Basically the 'netmask' relates to the global IP AND the local IP. For example, to translate 32 outside addresses to 32 inside addresses, use netmask 255.255.255.224.
If you're translating one outside address:
static (inside,outside) netmask 255.255.255.255
You can also leave off the whole netmask 255.255.255.255 text if it's one host, the PIX will fill that in automatically.
t805139 Thu, 10/18/2012 - 11:21
WARNING: mapped-address conflict with existing static
  TCP ISP2:0.0.0.0/80 to inside:0.0.0.0/80 netmask 0.0.0.0
ERROR: unable to reserve port 80 for static PAT
ERROR: unable to download policy
this does not seem to work
Julio Carvajal Thu, 10/18/2012 - 11:27
Please post the nat configuration you have and the command you are trying to enter,
