08-03-2007 06:55 AM - edited 03-05-2019 05:41 PM
I have two multilink interfaces connected. Can we somehow improve qos between them.
Central01#sh queueing int multilink 1
Interface Multilink1 queueing strategy: fair
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/3 (size/max total/threshold/drops)
Conversations 0/15/256 (active/max active/max total)
Reserved Conversations 1/1 (allocated/max allocated)
Available Bandwidth 1540 kilobits/sec
BFGWwan1#sh queueing int m1
Input queue: 5/1000/0/0 (size/max/drops/flushes); Total output drops: 1785
Queueing strategy: weighted fair
Output queue: 0/1000/64/1785/1737213 (size/max total/threshold/drops/interleav
es)
Conversations 0/24/256 (active/max active/max total)
08-03-2007 08:43 AM
In Cetnral01 router, you use CBWFQ and in BFGWwan1 router is WFQ. Why? Use the same QoS method in both router and post your QoS config of both routers if you need further assistance.
HTH,
hieu
08-03-2007 09:43 AM
version 12.4
service sequence-numbers
hostname Central01
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
class-map match-all voice-signaling
match access-group 193
class-map match-any voice-map
match ip dscp ef
class-map match-any voice-traffic
match access-group 102
match ip dscp ef
policy-map VOICE-POLICY
class voice-traffic
priority 768
class voice-signaling
bandwidth 8
class class-default
fair-queue
interface Multilink1
ip address 10.0.0.10 255.255.255.252
ip nbar protocol-discovery
ip ospf network point-to-point
ppp multilink
ppp multilink group 1
service-policy output VOICE-POLICY
interface MFR1
no ip address
interface FastEthernet0/0
description inside lan
ip address 10.10.10.2 255.255.255.0
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description ToCicero
bandwidth 1544
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/0
bandwidth 1544
no ip address
encapsulation ppp
ppp multilink
router ospf 10
log-adjacency-changes
network 10.0.0.8 0.0.0.3 area 0
network 10.10.10.0 0.0.0.255 area 0
router rip
network 10.0.0.0
neighbor 10.0.0.9
neighbor 10.10.10.4
ip default-gateway 10.10.10.1
ip classless
ip route 192.168.0.0 255.255.255.0 10.0.0.9
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit any
access-list 102 permit udp any any range 49152 53247
access-list 102 permit tcp any any range 50791 50801
access-list 193 permit tcp any eq 1720 any
access-list 193 permit tcp any any eq 1720
snmp-server community cherokee RO
snmp-server community libertY RO
08-03-2007 09:46 AM
version 12.2
service timestamps debug uptime
service timestamps log uptime
no service dhcp
hostname BFGWwan1
memory-size iomem 25
ip subnet-zero
no ip source-route
ip host BFGWwan1 192.168.1.41 255.255.255.0
ip name-server 205.171.3.65
match ip dscp ef
policy-map voice-policy
class class-default
fair-queue
class voice-traffic
priority 768
bandwidth 8
ip address 10.0.0.9 255.255.255.252
ppp multilink
ppp multilink fragment-delay 20
ppp multilink interleave
multilink-group 1
hold-queue 1000 in
hold-queue 1000 out
ip address 192.168.3.254 255.255.255.0 secondary
ip address 192.168.1.41 255.255.255.0
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
interface Serial0
no ip address
no ip redirects
no ip proxy-arp
encapsulation ppp
no ip route-cache
no ip mroute-cache
fair-queue
service-module t1 clock source internal
ppp multilink
multilink-group 1
interface Serial1
no ip address
no ip redirects
no ip proxy-arp
encapsulation ppp
no ip route-cache
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
router ospf 10
redistribute rip
router rip
version 2
redistribute ospf 10
network 10.0.0.0
network 192.168.1.0
neighbor 192.168.1.25
neighbor 10.0.0.10
no auto-summary
ip default-gateway 192.168.1.25
ip classless
ip http server
access-list 192 permit udp any any range 49152 53247
access-list 192 permit tcp any any range 50791 50801
snmp-server enable traps tty
banner motd ^C
