Errors while implementing CoPP in 7606/SUP720 3BXL (12.2SXD)
Aug 3rd, 2007
Hi I was following some instructions on how to implement Control Plane Policing in a 7600 series router (http://www.cisco.com/application/pdf/en/us/guest/products/ps1838/c1244/cdccont_0900aecd804ac831.pdf) and came across two problems....
While trying to match protocol arp under class-map cp-layer2-cm, I got the error....
QoS: match type in class cp-layer2-cm not supported on Control Plane Interface in PFC HW
QoS: policy copp-policy-in actions for class cp-layer2-cm are not supported on Control Plane Interface
Additionally while I was trying to police traffic under class-default, i got the error ......
Warning (QoS): Control Plane Interface: Problem installing policy copp-policy-in with class class-default. Class can only have
'match access-group' OR
'match ip dscp' OR 'match ip precedence' OR
'match dscp' OR 'match precedence' OR 'match mpls exp' OR
'match dscp' OR 'match precedence' with one of'match protocol ip' OR
'match protocol ipv6'
Any alternatives I could use to bypass the above?
