Deploying an AIR-AP1121G
Answered Question
Aug 3rd, 2007
Hello
As required, I'm proceeding with a AP1121G deployment by accessing http://10.0.0.1 at first boot.
According the quickstart manual, the http access is allowed during 5mn.
Isn't answering ping test, any ideas ?
thank you for help.
Lionel Pavy
Correct Answer by anandramapathy about 9 years 7 months ago
YOu are right the IP is 10.0.0.1
YOu can also detect what IP the DHCP server has assigned the Access Point & set a static IP to the Aironet AP. The Utility is call IP Setup Utility
The following is the procedure
http://www.cisco.com/public/sw-center/sw-wireless.shtml
Step 2 Click Cisco Aironet Wireless LAN Client Adapters.
Step 3 Scroll down to the Windows Utility section.
Step 4 Click Cisco Aironet Client Utility (ACU) for Windows.
Step 5 Click the file IPSUvxxxxx.exe. The vxxxxxx identifies the software package version number.
Step 6 Read and accept the terms and conditions of the Software License Agreement.
Step 7 Download and save the file to a temporary directory on your hard drive and then exit the Internet browser.
Step 8 Double-click IPSUvxxxxxx.exe in the temporary directory to expand the file.
Step 9 Double-click Setup.exe and follow the steps provided by the installation wizard to install IPSU.
The IPSU icon appears on your computer desktop.
Overall Rating: 5 (1 ratings)
Pavel Bykov Sun, 08/05/2007 - 03:55
  • Silver, 250 points or more
Check if you have the PC station configured for DHCP, and firewall turned off (the one that connects to AP)
We had to reset AP twice, before DHCP started working. Also after a while of connection, like 1-2 minutes after reset, renew IP using DHCP on a PC. (for example by doing "repair network" on Windows interface options)
anandramapathy Wed, 08/22/2007 - 06:01
  • Bronze, 100 points or more
Are you sure that the IP 10.0.0.1 ? or 192.168.0.1
To verify the IP Try connecting a Console to teh Access Point & type the following command
show ip int brief
Correct Answer
anandramapathy Wed, 08/22/2007 - 22:15
