Automated Voice When Transferring
Aug 3rd, 2007
I have a department that would like to change their Call Handling and need some assistance. Right now when you call you get a greeting stating the department and hours, you then get an automated message saying "Please Wail While We Transfer Your Call" and then the MOH while it is ringing in the department, it then goes into a Menu lisiting different options.
They would like for it just to ring on the callers end while it is ringing in the department instead of getting the automated voice and MOH.
Is there any way to do this? Any help would be greatly appreciated.
Overall Rating: 5 (1 ratings)
rob.huffman Fri, 08/03/2007 - 10:50
Hi NS,
For the Music on Hold, check the Device pool that the VM ports are associated with (look at the User MOH and Network MOH)
To delete the "Please wait while we transfer your call" message;
For Unity versions prior to 4.1 here is an excellent answer from Jeff @ Cisco;
For Unity versions 4.1 and 4.2 here is another great answer from Jorge @ Cisco;
Hope this helps!
ranpierce Fri, 08/03/2007 - 13:28
I think Jeff was being generous that day. hahahahaha.
really though this is not TAC supported
lindborg Sat, 08/04/2007 - 09:26
Just as a side note - in Unity 5.0(1) this option is properly configurable on a per handler/subscriber basis - you can turn on/off the system prompts for both the "please wait while I try that extension" prompt and the "record your message at the tone" prompt. Much cleaner, configurable at the object level and it's TAC and BU supported.
