Edison Ortiz Fri, 08/03/2007 - 11:48
  • Hall of Fame,
    Founding Member
The 3750 does not have the hardware to support NBAR. The only switch that is able to support NBAR is the 6500 and preferable with a FlexWAN card. Without the card, it runs in software and the CPU will be over-utilized.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hqos_c/part05/ch05/hdtnbara.htm
Regular routers have the hardware feature to support this kind of service and it doesn't affect its performance.
