Urgent Subnetting help needed
Aug 3rd, 2007
Hi All,
Could anyone be kind to help with the first six subnets of the following address 172.23.0.0/27 WITHOUT inclusion of subnet zero and please explain to help my understanding.
Newnetman
Overall Rating: 4 (2 ratings)
Edison Ortiz Fri, 08/03/2007 - 12:03
27 bits are on
11111111.11111111.11111111.11100000
5 bits are variable
2^5 = 32
You need a subnet ID and a broadcast address on each subnet, so starting with the first subnet.
172.23.0.0 [subnet ID]
172.23.0.1-30 [IP for Host]
172.23.0.31 [broadcast for that subnet]
172.23.0.32 [subnet ID]
172.23.0.33-62 [IP for Host]
172.23.0.63 [broadcast for that subnet]
172.23.0.64 [subnet ID]
172.23.0.65-94 [IP for Host]
172.23.0.95 [broadcast for that subnet]
And I will let you do the last 3. The logic is adding 32 to the subnet ID and broadcast address, whatever you have in between those 2 values, they are your IPs for the hosts.
HTH,
Jon Marshall Fri, 08/03/2007 - 12:05
172.23.0.32
172.23.0.64
172.23.0.96
172.23.0.128
172.23.0.160
172.23.0.192
You can use binary to write this out but a quick way to work it out
/27 = 255.255.255.224
256 - 224 = 32
So you subnets go up in increments of 32.
Jon
newnetman Fri, 08/03/2007 - 12:49
Hi All,
I am most delighted for all your magnificent responses.
I am so proud to call you all my invisible mentors.
May you all be bountifully blessed.
regards
