Locking down the "Settings" button on 7960 phone
Answered Question
Aug 3rd, 2007
Is there anyway to disable this button? I have security concerns with someone being able to access the network configuration on our lobby phone.
Thank you for your help.
Correct Answer by Rob Huffman about 9 years 7 months ago
Hi Brian,
Give this a try, disable the Settings Access parameter on the Phone configuration page. Complete these steps:
From the Cisco CallManager Administration page, choose Device > Phone, and click on the phone for which you want to prevent access to the Settings Button.
Choose Disabled for the Settings Access parameter under the Product Specific Configuration section.
When Settings Access is enabled, you can change the phone network configuration, ring type, and volume on the phone. When you disable Settings Access, the Settings button is completely disabled and no options appear when you press the button. The option Restricted is also available in Cisco CallManager version 4.1(3) and later. When you change Settings Access to Restricted, you can only access User Preferences and volume settings. By default, Settings Access is enabled.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00800a6763.shtml
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Fri, 08/03/2007 - 15:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Brian,
From this doc;
Hope this helps!
Rob
brian-utter Fri, 08/03/2007 - 18:19
Rob-
Thanks so much. This exactly what I was looking for.
Rob Huffman Sat, 08/04/2007 - 06:34
  • Hall of Fame,
    Founding Member
Hi Brian,
Good stuff! Glad to be of some help :)
Take care,
Rob
