NAT Setup
Aug 3rd, 2007
I need some help with setting up NAT on my cisco router. I know how to add port forwarding, eg. ip nat inside source etc... . My question is how do I remove this line or how do I change this line.
Jeremy
mohammedmahmoud Fri, 08/03/2007 - 13:23
hi Jeremy,
You need to clear the NAT translation table first, kindly use "clear ip nat translation *" command.
HTH,
Mohammed Mahmoud.
jheatherington Fri, 08/03/2007 - 13:52
Does this clear all entries in the nat translation table, and then you have to re-enter them all. Just making sure so that I don't forget to readd some.
Jeremy
