Phantom Call? anwser the phone to get a beep then disconnect
Aug 3rd, 2007
  • Silver, 250 points or more
Im having 1 user report that every now and then he either get's a call or a voicemail that has 1 beep then disconnects. Any idea's?
My first step is going through CDR's to see if i can find where the call originated from. any help would be appreciated on this one.
CCM 4.2.3 SR2b, OS 4.4aSR9
Unity 4.2 (all updates), TSP 8.1.3
Rob Huffman Sat, 08/04/2007 - 06:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Justin,
It sounds like this users number must be entered in the database of some company's "dialer" system. Usually when we have this happen I ask the user to supply the time and date of these rather annoying calls and then search their Missed Calls list from the IP Phones Call History directory. Contact the offending company and ask to be put on the "do not call" list and have the directory number removed from the dialer database.
Your idea of using the CDR records is a very good one as well but probably a little more work on your part :)
Hope this helps!
Rob
Justin Brenton Sun, 08/05/2007 - 06:39
Thanks Rob, Maybe I should of just asked you directly lol
Unfortunately we don't have external caller id from telus yet...It's in the works.
