Changing from WS-CAC-1300W to WS-CAC-3000W
juergen.fischer
Dear all,
we have a C6509 and tried to add another WS-X6516A-GBIC card to Slot 5.
The following error occured:
%C6KPWR-SP-4-POWERDENIED: insufficient power, module in slot 5 power denied.
We ordered two WS-CAC-3000W Power Supplies.
Before installation I've some questions.
1) Is it possible to use Hotplug function and change one Power-Supply after the other
("Someone" told us that mixed mode (1300 / 3000 Watt) may end up in unpredictable results ??))
2) Does the System support the new Power-Supplies without image upgrade or other changes ?
Many thanks in advance
Juergen
Find some more infos here (new card is removed):
dcdw0005/#sh power
system power redundancy mode = redundant
system power total = 1153.32 Watts (27.46 Amps @ 42V)
system power used = 1008.00 Watts (24.00 Amps @ 42V)
system power available = 145.32 Watts ( 3.46 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-1300W 1153.32 27.46 OK OK on
2 WS-CAC-1300W 1153.32 27.46 OK OK on
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 WS-X6K-SUP2-2GE 145.32 3.46 145.32 3.46 on on
2 WS-X6K-SUP2-2GE 145.32 3.46 145.32 3.46 on on
3 WS-X6324-100FX-MM 63.84 1.52 63.84 1.52 on on
4 WS-X6324-100FX-MM 63.84 1.52 63.84 1.52 on on
6 WS-X6516A-GBIC 152.04 3.62 152.04 3.62 on on
7 WS-X6516A-GBIC 152.04 3.62 152.04 3.62 on on
8 WS-X6516-GBIC 142.80 3.40 142.80 3.40 on on
9 WS-X6516-GBIC 142.80 3.40 142.80 3.40 on on
dcdw0005/#sh ver
IOS (tm) c6sup2_rp Software (c6sup2_rp-DSV-M), Version 12.1(26)E, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 23-Dec-04 17:03 by pwade
Image text-base: 0x40008F90, data-base: 0x418E8000
ROM: System Bootstrap, Version 12.1(4r)E, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-DSV-M), Version 12.1(26)E, RELEASE SOFTWARE (fc1)
dcdw0005/ uptime is 2 years, 24 weeks, 4 days, 13 hours, 34 minutes
Time since dcdw0005/ switched to active is 2 years, 24 weeks, 4 days, 11 hours, 50 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 17:53:49 CET Sat Feb 12 2005
System image file is "sup-bootflash:c6sup22-dsv-mz.121-26.E.bin"
cisco WS-C6509 (R7000) processor (revision 3.0) with 112640K/18432K bytes of memory.
Processor board ID TBM05398867
R7000 CPU at 300Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
19 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
68 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 112640K/18432K bytes of memory.
Configuration register is 0x2
Juergen, thanks for using the rating system. if you have more questions come back, the forum is always here to provide help .
Rgds
Jorge
Jorge Rodriguez
JORGE RODRIGUEZ
Level 10
Level 10
refer to this link for effects on power supply changes..
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a2d.html
as for code I feel you do not need upgrade since you already have two WS-X6516A-GBIC blades running with no issues, but as usual if in doubt it is a good practice to check your current code for bug reports on a regular basis.
Bug-tool
http://www.cisco.com/en/US/support/tsd_most_requested_tools.html
Jorge
Jorge Rodriguez
Hi Jorge,
many thanks for your link to the effects on power supply changes.
I rated the post, but maybe I've missed to set the checkbox for "solved Author's issue"
I'm sorry for that.
Maybe a moderator can do that.
Many thanks.
Juergen
Rgds
Jorge
Jorge Rodriguez
