Rate-Limit number of connections from a source
Aug 4th, 2007
Hi, we currently have an application thatcustomers connect to in order to sent bulk sms messages. Since application level cannot enforce max number of connection per client, I was wondering if there is a way to do it using PIX 7.x.
For example we may need to enforce that customer X can open 10 connections to application while customer Y can open 5 connections to the application.
Overall Rating: 3 (1 ratings)
pavlosd Sat, 08/04/2007 - 06:37
Hi again,
I Just realise that there is a conn-max command under policy-map for actions....
fw(config-pmap-c)# set connection ?
mpf-policy-map-class mode commands/options:
advanced-options Configure advanced connection parameters
conn-max Keyword to set the maximum number of all simultaneous
connections that are allowed. Default is 0 which
means unlimited connections.
embryonic-conn-max Keyword to set the maximum number of TCP embryonic
random-sequence-number Enable/disable TCP sequence number randomization.
Default is to enable TCP sequence number
randomization
timeout Configure connection timeout parameters
So what i did is created a class-map for each customer and under policy-map set the number of connections.
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/mpc.html
purohit_810 Sat, 08/04/2007 - 08:45
  • Silver, 250 points or more
access-list tcp_inspection extended permit tcp any any
access-list tcp_inspection extended deny ip any any
class-map my_inspection_tcp
match access-list tcp_inspection
policy-map global_policy
class my_inspection_tcp
set connection embryonic-conn-max 1
service-policy global_policy global
If in case above will not Wok properly than second option is websense authentication.
Define on wesense One Group, Put all are IP adress that uses by CuSTomer. Define that group MAX connection.
You can also define On websense .. Maximu time of access, amount of Access Limit etc.
Dharmesh Purohit
