VTP Pruning in a 6509 and 3560 Envinroment
Aug 4th, 2007
We have an environmet with a 6509 in top whitch is the root for the stp and 150 operational VLAN's.
We applied vtp pruning to the domain but we did not get results.
All the VLAN's are in the non pruning state at trunks.
Has anyone had the same problem
I will appriciate very musch an answer.
Thanks ;) Reg
royalblues Sat, 08/04/2007 - 05:03
  • Green, 3000 points or more
If you have ports in all the 150 vlans, then that vlan would not be pruned from the trunks.
Pruning for a vlan occurs only when there are no downstream ports in it.
Narayan
royalblues Sun, 08/05/2007 - 13:22
Do you have any switch which is not VTP version 2 capable
I think VTP pruning can only be enabled on switches that are VTP version 2-capable, so all switches in the domain must be version 2-capable before you enable pruning.
The switch must only be VTP version 2-capable, but does not have to have version 2 enabled, to turn on pruning.
HTH, rate if it does
Narayan
reglend-xhango Sun, 08/05/2007 - 13:35
ALL switches are vtp2 version enabled
at vtp status it shows it
VTP Version : 2
Configuration Revision : 213
Maximum VLANs supported locally : 1005
Number of existing VLANs : 143
VTP Operating Mode : Client
VTP Domain Name : xxxxxx
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
