priorities between hosts in same subnet
Aug 4th, 2007
Hi all,
i want to give priority between hosts in the same subnet.for example hostA,hostB,hostc,hostd.
i want to give priority to traffic b/w hosts A&B than hosts A&C.
how may i proceed?
thanks in advance
Richard Burts Sat, 08/04/2007 - 12:46
If traffic originates in one subnet and the destination is in another subnet, and if the traffic must be forwarded by a router, then there are some things that you could do to prioritize traffic between a pair of hosts. But if the source and the destination are in the same subnet then they will communicate directly and there is not anything that you can do to prioritize that traffic.
sakthicisco Sun, 08/05/2007 - 23:39
Thank u Rick,
I hav some doubt in connecting layer 3 switch to layer 2 switch.
Between layer 3 switches (i think similar to routers connection),i connect through fiber optic and give ip address on both ends.
But if i want to connect b/w layer2 and layer 3 switches what sud i do?
plz detail me...thank u in advance
sakthicisco Mon, 08/06/2007 - 00:21
Hai thomas,
i dont hav any vlans right now.
i want to connect distribution switch 2950 and core switch i hav to give any ip address at the end connecting to 3750 switch?
As the port in 3750 connecting to 2950 is given ip routing,we need to give ip the link b/w 3750 and 2950 sud b in a single subnet?
thanks in advance
