vpn client 5.0.0x and Verizon Aircard(EVDO) connection on Vista
Aug 4th, 2007
When you initiate a vpn connection using the any version 5 of the vpn client as soon as it starts Phase 2 negotiations it drops the aircard internet connection and somehow messes up with the drivers for the air card , because at that point the Laptop (vista) does not see the air card as installed and starts promptiing you to install PCMCIA drivers for MTD-0002 but if you reboot the Aircard comes up fine and you can connect to the net. the Aircard works ok with Ver 4.8.xx on XP but has the same error on Vista, Any ideas?
