H323, FXO, calling number doesn't work
cjrchoi11
CCM5.1.2, IOS12.4.11.T3, VIC2-4FXO
when I dial out via FXO, CCM sending to gateway the calling number '4501119991' successfully but lost in gateway and cannot send out to PSTN.
Advise please,
configuration
voice-port 0/0/0
connection plar opx 5100
caller-id enable
dial-peer
dial-peer voice 220 pots
destination-pattern 9[2-9]..[2-9]......
port 0/0/0
forward-digits 10
debug voice dialpeer
*Aug 4 14:39:14.722: //-1/00BB48670C00/DPM/dpAssociateIncomingPeerCore:
Calling Number=4501119991, Called Number=94502223333, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=101
*Aug 4 14:39:14.730: //-1/00BB48670C00/DPM/dpMatchPeersCore:
Calling Number=, Called Number=94502223333, Peer Info Type=DIALPEER_INFO_SPEE
CH
Match Rule=DP_MATCH_DEST; Called Number=94502223333
*Aug 4 14:39:14.734: //-1/00BB48670C00/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
*Aug 4 14:39:14.734: //-1/00BB48670C00/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=220
Yes, you cannot send calling number on analog lines. If you want to do that, get ISDN.
cjrchoi11
it may stupid question since the analog calling number (outbound) is controlling by carrier. cannot send out my calling number. Am I correct?
