Sidewinder firewall with two 3750 Switches
Aug 4th, 2007
Hi Folks,
I have two sidewinder firewalls connected to two 3750 switches.
The sidewinder is creating a virtual IP address and a virtual MAC, unfortunately the switches are not able complete the ARP for this virtual IP.
Once we do a static arp, things goes fine.
the question is : Any one have any idea of what is going on? any one had the same scenario before?
I thank your cooperation in advance
Ismail
purohit_810 Sat, 08/04/2007 - 09:07
  • Silver, 250 points or more
Can you check by disable CDP on switch.
Which IOS do you have?
Dharmesh
