jbarcena Sun, 08/05/2007 - 15:31
On the CallDetailedRecord table look for the call that you made, then the following fields should tell you if it is an incoming or outgoing call:
- origDeviceName
- destDeviceName
//Jorge
calvinzhao Sun, 08/05/2007 - 18:41
Thanks a lot!
And it's really helpful, but could you show me some examples?
Thanks again!
